hi,
i used to have a vesa mount drilled into the wall but that isn't going to work any more as i've moved and don't want to drill into the wall.
So i'm look for an arm that for a desk thats right up against the wall and doesn't extend very far out.
A clamp also wont work so it would need to go through a drilled hole.
any ideas?
a lot of the ones i see have a clamp or a very long arm that is just going to push the monitor too far forward.
cheers
any ideas?
cheers
