Air Cooling The 3700X
25 Sep 2018
Hello all,
I may decide to get the 3700X for my next build which will be all air cooled. I was wondering what air cooler to use for my 3700X. Can anyone recommend any air coolers? I was the I king of going for the Noctua NH-U12S, although I’ve also been recommended a Scythe cooler. Would the Noctua give me good temps when my CPU is overclocked?
Thanks.
There’s been a few good reports knocking around about the new Zalman cooler. Initial tests had it beating the flagship Noctua cooler but ongoing benching seems to have them fairly equal. The Zalman is a fair bit cheaper too.
The all black Noctua D15 is aesthetically pleasing, but slaps your arse with the price.
Yes, I’ve heard good things about that cooler. Is there any potential RAM-blocking issues with the Pro 4?
Probably,not sure on that cooler,if using low profile ram I think you'd be ok
Another cooler to consider is the arctic freezer 34 esports,but I doubt it would be as good as the expensive coolers
Okay, thanks for your advice. I’m looking to get some Ryzen optimised RGB memory so as long as the cooler doesn’t hang over the second memory slot I should be okay.
Just a heads up. When you buy an air cooler, check to see how tall it is. Then check to see if said cooler will fit in the case of your choice. Reason is I bought a Lian-li PC-011 Dynamic without checking the max height for an air CPU cooler. Turns out most of the recomnended big air coolers wont fit (too tall) I also bought a Thermalright Macho SBM & didn't check the height of that either! Good job it fitted! :D
Yes, that’s something I need to keep an eye on. The case I’ll probably go with, a Meshify S2, should give me plenty of room, but I don’t want a massive air cooler to take up most of the space inside it. Purely for aesthetic reasons admittedly.
When overclocking there's no such thing as too much cooling power and you'll want the best cooler fitting into your requirements.
And you don't really overclock Ryzens in traditional sense.
At least if you play games.
Ryzens boost the most heavily loaded cores automatically very agressively (depending on also how well CPU is cooled) compared to silicon's capabilities and reaching similar speeds with manual all core overclocks is very hard.
Especially with higher core count CPUs.
And shouldn't be surprise that if clock speed doesn't reach same, that causes easily performance regression in games.
Again fast memories help to boost especially minimum framerates.
Overpriced brand hype Noctua is worser in also that compared to Scythe Mugen 5.
Which has actually better DIMM clearances, because of Noctua failing to master the dark magic of offset finstack:
https://www.tweaktown.com/image.php...scythe-mugen-5-rev-cpu-cooler-review_full.jpg
https://www.tweaktown.com/image.php..._32_noctua_nh_u12s_cpu_cooler_review_full.jpg
Yeah... Despite of being anorexic in comparison NH-U12S is worser in those because of Noctua using more money into marketing hype than actual product.
https://www.tweaktown.com/reviews/8320/scythe-mugen-5-rev-cpu-cooler-review/index5.html
https://www.tweaktown.com/reviews/5417/noctua-nh-u12s-cpu-cooler-review/index7.html
Scythe even bundles proper screwdriver, while "poor" Noctua gives bent piece of wire, which is clumsy to use.
(and using normal short screwdriver is nightmare for skin of the knuckles)
