- 27 Dec 2005
- Bristol
We had some platation shutters fitted yesterday from John Lewis. They were about the same as a local carpenter (cheaper on two occassions) and although I often prefer to buy local, I feel with things like this it's just easier, both to order but also to escalate when things don't go well.
Cut to now. We were going to complain anyway because we ordered on 23rd October with a 10-12 week lead time and they were only fitted yesterday, so there's that. But that's an aside/easy to complain about!
We've had them fitted both downstairs and upstairs and in both the bay windows they look fantastic. Well fitted, good quality and the guy has done his very best working around non-right angles etc as you'd expect from a period house.
But we also have a side window upstairs and it just looks weird. It's basically sized to match the window, not the alcove, and so you've got a gap top and sides of ~8-15cm. Apart from being a dust and dirt magnetic it just looks weird. I get that if they fitted the alcove then you'd see part of the plastic window fitting behind the shutters when open but I feel like that'd look a lot better - especially when closed, obviously.
Those that have had similar windows done, what are your thoughts? Should they fit the alcove or the window?
