Hi folks,
I'd really appreciate your advice on the matter if you have a potential tip. This 2009 Jaguar XK was running smoothly with no issues. It was a very strong wind here last week, a storm. So at night I moved the car from the gates reversing slightly up the hill and parking sideways. Was a quick move, didn't let the engine run properly.
Next morning it cranks but won't start. Recharged the battery as the first suspect - no luck. Tried hacks with brake pedal and start button - same.
Attached you will find videos of the car starting and readings from the OBD port with OBD Fusion app.
Have some ideas what to do next, but would love to get your input first.
Car cranking sound:
OBD scan, part 1:
OBD scan, part 2:
Car cranking sound:
OBD scan, part 1:
OBD scan, part 2:
