- 25 May 2008
- North Wales
To be fair a lot of modern cars don't even have a sump drain plug now and the only way is to use an oil suction pump.
Wrong on every point made!
Exhaust heatshield: Regardless of whether it's an mot failure or not I was concerned with what it was shielding, and having a look underneath while up on the kerb (we were away) I could see plastic brake lines right next to the exhaust pipe. The manufacturer put it there for a reason, that's why I did the temp fix to get home and did a permanent one once home.
Sump plug. It's a torx plug presumably made of alloy because I took a standard ratchet to it with a t3 male torx bit and it chewed it like cheese. A breaker bar would do nothing.
Coolant. Coolant doesn't last forever, long life should be changed at 10 years, which I did at 10 years.
You mean plastic coated, so non issue, and yes heat shields around the backbox are overkill. In fact, why do you have brake lines near your backbox?
A T3 torx bit you say. Is it a matchbox car. Don't mistake torque for power. A short ratchet will not provide the same low torque has a breaker bar. You'd be amazed what a long bar will slowly and gently unscrew.
You've been topping up the coolant. Cars don't use coolant (my point) unless there's an issue.
To be fair I had a VAG specialist refuse to drain my oil without signing a disclaimer because my sump plug had "dissimilar metal corrosion". I bought a Pela oil extractor, started doing my own servicing and haven't looked back since.
Whether that really was the case came into question when the same "specialist" diagnosed a faulty alternator as causing voltage drops on my car when started from cold, despite a stored error code for a faulty secondary air pump which they insisted wasn't the problem... guess what fixed it![]()
I'll admit to having done a bodge or two over the years. That secondary air pump was replaced by a resistor covered in waterproof tape, my wifes old Punto had a corroded battery clamp fixing point "fixed" by using two small ratchet straps instead, also a broken and rattly windscreen vent "fixed" by wedging in a piece of foam. Even my MX5 has a current "fix" for a constant current drain which is to remove the permanent 12V fuse![]()
My Saab crapped its 5th gear gear. I bought a second hand box for 150 and a clutch kit for 300. All genuine parts. For most people that would be a scrapped car. That's what bangernomics is to me.
I hate Bodges and have to fix everything. I bought a new washer bottle cap for my Saab because it snapped off due to fatigue.
The OP's stuck sump plug would bother me. I would either try and remove it in situ or get hold of a second hand sump and replace it.
A quick Google shows a brand new sump for a Mk5 Astra can be picked up for £20 but op spent £20 on a pump.
but, presumably you never end up with an arm full of warm oil, fishing for the sump bolt, or mopping up an oil flood.not a viable long term solution for a car, you ultimately end up with a gradual buildup in the sump as the pump can’t pull it all out.
recent thread about torx bits .. but quality counts ... I have chewed up bolts because the fit is non-optimal ... some of these (Chinese/cream-cheese...) bolts you only get one chance.Sump plug. It's a torx plug presumably made of alloy because I took a standard ratchet to it with a t3 male torx bit and it chewed it like cheese
I am 99% sure a stud removal socket would take out the plug no problem and they cost peanuts for a set.
https://www.ebay.co.uk/itm/223761555508
I used a similar set to remove a torx bolt on a gearbox linkage on my Saab as the torx was rounded off.
My 12 year (at the time, sold 2 years ago) Corolla was kept on the road economically by doing regular preventative maintenance.
My 26 year old Volvo 850 is also being kept on the road economically by preventative maintenance and finding the causes of any issues (like minor coolant leaks) and addressing them using good used parts (unlike you) or high quality aftermarket parts (also unlike you).
My fiance's 15 year old Corolla gets treated the same way mine did. The only fixes beyond regular servicing are detailed below:
- ABS sensor died, bolt was stripped. Bought used sensor on eBay for a tenner and a brand new bolt from Toyota for 87p.
- Alternator died. Bought refurbed one for £120 with next day delivery as the car was needed for work. Replaced bushings in old alternator, cleaned it up a bit and sold it. Total cost was around £40.
- Drain plug was rounded off. Used a breaker bar with bolt extractors to remove, bought a new one for £1.64. Damn sight cheaper than £18.
- Stuck caliper slider pin, which was corroded due to boot splitting. Replaced pin for 86p, spent £5 on fitting kit and changed all boots and clips all round.
The point in trying to make is that the best way of keeping an older car on the road and to do so economically is proper maintenance. Not bodging minor inconveniences, but addressing them. Stuff like bolts are so cheap through dealers that there is no point in not replacing one. Larger stuff like coolant header tanks are so cheap used or aftermarket that again there is no point bodging your way around the issue.
This is in a mk1 so nothing as fancy as thatRe the mx5 current drain, have you replaced the oem stereo with an aftermarket unit? Apparently there's a bluetooth module behind a panel behind the seats which can cause a drain until it's removed. I've just replaced the oem Bose unit on my mx5 for a double din unit but it's my daily so no obvious noticeable drain.
I did fit the old Alpine unit out of my wifes car and initially thought that might be the problem so I removed it and the problem remained. I spent a fair bit of time going over everything disconnecting things and pulling fuses one at a time but whatever I did I ended up with a drain of 200mA + while the 'room' fuse was in... which on a car I use a couple of weekends a month became a bit of a chore! I wonder if the alarm may be at fault, when (if!) I get a decent chunk of time in the summer I'll investigate it more.
