- 29 Sep 2010
So I’ve built my loop, all seems decent and kind of in line with what I was expecting although I haven’t overclocked yet.
I have a magicool slim 360 and 280 rad, 3 x nb eloop fans on the 360, 2 x ek vardars on the 280. They’re basically silent which is nice.
When I first built it (window was off) I had idle of about 21-22 for the cpu and gpu, now with the panels on it is around the 30 degree figure, not sure if this is normal or not but it’s a case with lots of space (enthoo luxe) so probably not a lot I can do. Please note my tubing goes behind the rear panel, so I’m a little conscious that a small amount of pressure might be restricting the flow to the cpu? Going to take the rear panel off tonight and just test that theory.
Now, when I run stress tests, the cpu temp will spike almost instantly to about 50 then settle at about 55, it’s a Ryzen 1600af on stock clocks.
When I run a GPUs stress test, it’ll start at about 30 but then creep degree by degree to about 43 and then stay at that figure.
Is this normal for CPU’s to behave in this manor or is it likely I have a mounting issue? Everything was tightened in a cross pattern and seems firm on the block. With how the loop is assembled I think it might be quite difficult for me to slide off the block and reapply
hoping to tinker and monitor tonight with some games
