Temperature monitoring and fan speeds
20 Oct 2002
Oxfordshire / Bucks
Hi all
Trying to find some software to help with the following temps and fan speeds :
CPU Temp
GPU Temp
Motherboard Temps
etc
CPU Fan speed
GPU Fan speed
Motherboard Fan speeds (if applicable)
Case Fan Speeds
Air Temp (is there something i can place in the case for this?)
Is there some software that i can see all of this one one program and adjust as necessary ?
Looked at Core Temp (gives Fan speeds of 65000 !!)
HW Monitor
MSI Afterburner
thanks
Argus System Monitor will do all that except air temp and let you control all your fans including CPU and GPU to fine tune noise and temps.
Comes with a free month of full use, then it's around $20 for a 3 year subscription, I would never normally pay for something like that, but it's so good I happily paid for it after my month was up and I'll keep it in builds from now on.
Allows me more fan control than bios or other utilities like Fan Expert, etc.
Some DC fans will only run at 50% minimum in bios, Argus can safely set them even lower for much quieter idle operation, you could arguably tune any PC with decent cooling for silent operation at idle using it, whether they're DC or PWM fans.
As PC777 said, monitoring air temp in case and/or room is not something any software monitor that I know of does. Simple way to monitor air temp going into cooler is cheap digital indoor/outdoor wired sensor thermometer or similar digital thermometer for aquarium, terrarium, frig, etc. use. Many available on e-bay or similar, but they don't keep a record. At end of below link is image of one of mine.
https://forums.overclockers.co.uk/t...-i-put-my-temp-sensor.18564223/#post-26159770
Some motherboards can monitor
Air temp
Think my aorus ultra had a couple of temp sensor wires in the box
Though I never bothered using them
But you can stick them wherever
You like to get a temp reading
I match to system temp, something like 16% on arctic P12 @ 10 20, 30C and then 45C 100%
So it's a flat silent curve until the GPU heats the case up and then they ramp up
i got MSI command center loaded and seems to work
could do with an OSD for temps, so that when im playing game or stress test i can see what temps are like when i change fan speeds
Trying to use turbocharger as cooler?:p
If using just PWM fans Aquacomputer's Quadro would be the way most versatile for controlling fans.
You can use both software readings and physical sensor readings as base for control.
https://www.overclockers.co.uk/aqua-computer-quadro-pwm-fan-controller-wc-338-aq.html
And they went literally off the charts in programmability...
https://forum.aquacomputer.de/weitere-foren/english-forum/109453-breaking-all-limits-aquasuite-x-6/
