X570 aorus master
Yeah. I just selected xmp in the bios. Booted. Installed windows, chipset and ryzen master.
I've uninstalled master to see how I get on.
I notice 1.45v in cpu-Z for cpu, so I guess need to do some tweaks in the bios.
Is the pc running properly?
Those codes aren't just for errors
They are also successful
Inititiation codes
For example xxx code could mean
Cpu successfully posted
If everything is fine
Ignore the code don't try to fix
Something that's not a problem
OK uninstalling ryzen master has fixed that issue.
So I'll run without that until I understsnd everything a bit more.
Is the a dummies guide to x570 master with 3900x?
OK ryzen master back on.
Trying to get temps down. Playing with profiles now.
I've left everything to default/auto in the bios other than setting to XMP.
1.47v at idle in cpu-Z!!!!
Seems I can set voltage in ryzen master... Lots to learn.
1.4v or so is normal under light load for a 3900x
current voltage on left
minimum in middle==that was testing low power mode
max on the right
average on very far right
https://imgur.com/fw8o0Eh
edit sorry insert image is playing up
fw8o0Eh
