Upgrade advise 2k budget
3 Jun 2007
Essex
Hi All.
Got the upgrade itch as I have not upgraded in the last 3 years so thinks about time.
Current spec is as follows
i7-6700K overclocked to 4.5 ghz
16gb 2400mhz memory
Nvidia geforce GTX 1080
This is all in a custom full loop so everything is water cooled.
So for cpu/mem/mobo/storage I am thinking this set-up
My basket at Overclockers UK:
Total: £1,176.41 (includes shipping: £10.50)
Now this bit I am not sure on is the graphics card.. I know budget does not allow for a 2080ti (Especially as i need a water block on it as well) but i was researching the 2080Super with the EK block on it which would equate to this
Total: £2,055.94 (includes shipping: £11.10)
That pretty much hits budget but I am guessing my question is... is the 2080Super enough over my current 1080 (Gaming at 1440p) or should i get the rest of the components and keep my 1080 and wait for ampere and see what that brings?
My 1080 is OK at that res but i do have to lower certain settings to get best performance. looking at some videos comparing the two depending on the game in looking at anywhere between 30-50fps uptake in most games
thoughts?
from a 6700k + 1080, i don't think any of the current gen parts (cpu and gpu) gives a decent value/performance upgrade to be shelling out 2 grand.
up to you i guess.
i'd wait for ryzen 4000 and rtx 30xx parts at minimum
Exactly what I said ;)
For games. Minimal improvement. Just hold off.
Of course if you can harness multicore eg video encoding then obvs high core count Ryzen would be much better. But for games...not so much.
