- 14 Apr 2014
- Hampshire
Hi all
I don’t do too much driving at the moment, and it’s generally shorter journeys to and from shops, however I try to take my car for a good run every 2 weeks to keep the battery charged.
I’ve noticed that for the past few months, even after doing a 2 hour journey, the battery isn’t charging all that much. Stop start will re engage, but only for a handful of times before it doesn’t work again.
I have a low profile aftermarket sub installed, due to rattling door speakers (took some of the load off of them), but it shouldn’t use that much juice. All LED bulbs.
If I charge the battery using a CTEK the charge lasts a lot longer than doing a journey in it.
Car is a 63 plate and original battery I think.
Any ideas? Battery or alternator issue?
