- 21 Jul 2005
- Officially least sunny location -Ronskistats
If you apply all mitigations including the software/Windows patches and some of the firmware updates designed to reduce the performance impact, etc. then the performance penalty will vary a lot depending on task there isn't really a set "25% slow down" some things performance isn't impacted at all other things there is a small to moderate hit. Personally I've only used a small number of updates to protect my external exposure and the performance impact is mostly so close to 0% at worst it makes no difference - talking within error margin differences - there was one thing with ~3% reduction but I can't even remember what that was.
Listen man, Im only saying what I keep reading. Im not gonna trawl the web for every one of them but just take a look at a result in my first search I get this. Its probably way off or exaggerated, but come on close to 0% and max 3% your in fairy land.
