Hi,
I am planning to build my first custom loop with Corsair Hydro X series stuff for CPU and GPU. Currently I am running with:
My question is, which of these setups below will be better for the system in regards to temps? I am running fans up to 1200-1500RPM, like to have my system to be silent.
Thanks
- Corsair 750d case
- Ryzen 2700x stock 105W
- Sapphire Vega 64 Nitro+ undervolted and memory overclocked. In fire strike extreme test it draws around 225W
- 280x140x30 16FPI at the front of the case in push as intake and 2x120mm case fans at the bottom also as intake or
- 240x120x54 13FPI at front of the case in push/pull as intake and 240x120x30 16FPI at bottom in pull as intake, I think I can fit these two radiators an fans in this case
- 240x120x30 16FPI at front of the case in push as intake and 240x120x30 16FPI at bottom in pull as intake
Thanks
