The Elder Scrolls V: Skyrim - MODS & TWEAKS
Caporegime
OP
8 Sep 2006
On Ocuk
Hey guys if you use Vivid Weathers which I do because it looks amazing ( if not still worth trying over other weather/lighting mods) try
Vivid Weathers SE - Brighter Nights/Light Fix
https://www.nexusmods.com/skyrimspecialedition/mods/32406
Without it you'll have horrible yellow bright colours with torches and other burning objects, this makes it look oh so much better. See image above for reference
Caporegime
OP
8 Sep 2006
On Ocuk
Glorious Doors of Skyrim (GDOS) SE
https://www.nexusmods.com/skyrimspecialedition/mods/32376
22 unique new door meshes, replacing 42 door meshes ingame used in hundreds of instances!
:D :D :D :D :D
Obviously remove any DOOR replacement mods prior to installing this :D
Caporegime
OP
8 Sep 2006
On Ocuk
IMPORTANT UPDATE !
Fores New Idles in Skyrim - FNIS
2020/02/18
FNIS Behavior 7.6, FNIS Behavior 7.6 XXL
Recognize newest XPMSE skeleton bones (126/156) for XP32 Maximum Skeleton Extended - XPMSE Version 4.60 and above
Fixed a bug that prevented the PSCD patch
Added ini parameter "LoadCTDCalculation=0"
Reduced output about Load CTD Calculation (see Note)
Fixed patch mixup when switching between different languages
Updated russion language file (thank you, kapasov)
Creature Pack V7.6: fix exit animation event names (capitalization, FrostBiteSpider + Mudcrab)
https://www.nexusmods.com/skyrimspecialedition/mods/3038
Caporegime
OP
8 Sep 2006
On Ocuk
WOOHOOO!!
I've finally found the ENB for me and it works amazingly well with VIVID Weathers!
Desmond's Lusty ENB - PhotoRealistic - Vivid - Picturesque - Obsidian - Cathedral - NAT - ELE - ELFX - RLO
A Peak PhotoRealistic ENB Which turns your game into Eye-Pleasure with little to no FPS impact! It's highly customizable! Everything can be changed to your liking!
https://www.nexusmods.com/skyrimspecialedition/mods/29700?tab=description
6 Jan 2013
Rollergirl
I've got a fully modded version of the game available if anyone is interested in trying it out. It should mean a single download and then a couple of minimal tweaks and you're off and running.
Send me a Trust if you want to try it out.
Oh, and you need to own the game as it's just the modded extras I'm making available. :)
Caporegime
8 Sep 2005
Utopia
Thanks chap but without further details as to what mods you use it's abit hard to judge whether it's worth the download?
13 May 2003
Just updated Windows 10 and my FPS in Skyrim has utterly crashed, virtually unplayable. Anyone else had this problem? I'm scratting round to see if there any driver updates that might fix things for me.
Caporegime
OP
8 Sep 2006
On Ocuk
I've upgraded to a 2070 GTX and wow what a difference! It's perfectly playable with an ENB now! Obviously dropping to 50fps in heavy modded parts ( JK's mod ).
Still tweaking :D
Nice screenshots btw!
Caporegime
8 Sep 2005
Utopia
Dude what is this... 2010? Without knowing your specs or if you did a fresh install or just a upgrade over the top of your old Windows 7 install then this question is impossible to answer. :p
