World of Warcraft build and streaming
3 Jun 2015
I’m looking to buy a pre built machine, my 6 year old PC is constantly freezing and I just think it’s on its last legs. I mainly play world of Warcraft and I’d like to be able to stream it as well, whilst streaming music and having other pages open without struggling. I do occasionally play things like Destiny 2 on the PS4 the ability to play this on PC would be an advantage but not a deal breaker. Eventually I will be connecting to a 4k TV or monitor so this could be factored in as well.
Thanks in advance for any help and advice.
Budget whilst not cheap I’d like to stay around the £800-£1k max. If cheaper all the better. I already have the peripherals so this is all about the main box.
You can either go onto OCUK and configure one of their prebuilds or you can pick the parts yourself then post a message in the customer service section asking them to build it for you which they will do for a fee etc. If you built it yourself then you could save on fees and put that extra money into your parts.
This is what i would be looking at for around 1k
My basket at Overclockers UK:
Total: £998.59 (includes shipping: £11.70)​
honestly you need much less than that for WOW, check my build in the signature, that's what i've been using for mythic raiding and streaming without problems
this should be fine for WOW, if you play competitive you will have the graphics on low anyway
Total: £791.49 (includes shipping: £12.60)​
From Experience WOW favours clock speed over GFX card.
Personally I play WOW at 1440p using a 1660ti, with everything pretty well maxed out, but use an intel 9700k at 5ghz and the CPU speed is critical, not the cores. This is one game you can cut back on the graphics card, but not the clock speed of the CPU, 4.4 GHZ vs 5 GHZ for WOW matters. I would go AMD every time for everything else, but not WOW.
Ok thanks, i did fancy jumping into destiny 2 and Diablo 4 when that comes out as well, so think I’d try for a decent graphics card as well, it doesn’t need to be top dog bit something that will see me through a few years.
