Steering wheel stand
27 Mar 2016
Bristolian living in Swindon
Hi all
I've recently purchased a Logitech G920 and want a stand to fit it to... I've had a shop around and came across one at £40 from a certain auction site...
Has anyone used one before?
I'm not looking to spend silly amounts yet, I've fitted it to my desk but its not 100% secure so I want something I know it's safe on
Any help appreciated
Cheers
I have a GT Omega which is very good. It weighs an absolute ton though. I do wonder whether I'd have been better with one of the 'play seat' ones which has less metal to it, and gets its stability instead via tension on strapping cords. Might be a bit lighter and easier to set up and put away.
Thanks for the options guys, very helpful
@Mr G That's a smart one, does it fold away pretty small?
I've had it a few days now and it's the best I've used. I sent a GT Omega stand back and replaced it with this, the quality is on another level to say the least and folds away easily.
May have to look at one of these then... Storing it away is something I need to consider as we live with in laws :)
I got it for £99.95 of a well known auction site, if you need a link PM me. This is a hidden gem that shouldn't really go unnoticed.
I tried fitting my wheel to my desk but for some reason it still slides around that's why I need a stand
I was forced into buying a stand as I have an IKEA desk and it's seriously thick which made fitting the Logitech G29 impossible, really can't recommend this enough.
