Hi all.
Bought an MSI 2080 Ti, Gaming X Trio.
After knocking through a wall in the house to fit it in, I had it up and running.
I was getting 13,500 scores on 3D Mark with just the simple OC scan and curve overclock that's built in to the Afterburner software, plus increasing the power limit to the theoretical max. However it won't pass the stability test.
I have had to revert all parameters to default to get it stable.
It seems this new generation of cards really overclock differently.
What parameters should I adjust first and then test? I really need some basic advice for getting this thing stable.
I have also added a water block to add to my custom water-cooling loop and the temps are looking good, never above 65C under full load. I think I have headroom to OC but anything I touch leaves it unstable, or would you not rely on the stress test in 3D mark too much?
