- 26 Nov 2014
- Stoke
Available for preorder today, we have the new Raijintek Ophion and Ophion Evo. The Ophion is a small form factor chassis that aims to pack as much hardware support into it's small dimensions as possible. The Ophion has an aluminium exterior with a pair of tempered glass side panels that gives it a premium look from the start. A dual slot 330mm VGA card can be installed vertically using the supplied PCI-E Gen 3 Riser cable, and the Ophion supports Mini-ITX motherboards, 85mm CPU coolers, has space for 3 x 120mm fans and even has a USB3.1 Type-C port on the front I/O. There's room for a 3.5" HDD and up to 3 x 2.5" SSD's or HDD's. In addition, the Ophion Evo has more internal room due to the increased height, and can accomodate a 240mm radiator on the top panel, along with room for an extra 2.5" SSD/HDD.
Stock is due in 7-10 days, and I'm thinking Raijintek have done well with this case considering the cost of the competition. Preorder now!
Raijintek Ophion Mini-ITX Case - Black @ £119.99 inc VAT
Small form factor (SFF) case - 375x174x245mm (DxWxH), Dual Tempered glass side panels, Vertical mounting for Motherboard and GPU, Holds graphics cards up to 330mm long
Only £119.99 inc VAT.
ORDER NOW
Raijintek Ophion Evo Mini-ITX Case - Black Window @ £129.95 inc VAT
Small form factor (SFF) case - 375x174x290mm (DxWxH), Dual Tempered glass side panels, Vertical mounting for Motherboard and GPU, Holds graphics cards up to 330mm long
Only £129.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
