- 19 Mar 2020
I believe I have an issue with this GPU after testing it in two computer with the same issue. When playing any sort of games I will get a full green screen and a reboot after 5-10 seconds. This is at completely random time within the game, could be at the start menu or 30 minutes of play time.
I swapped the GPU out for a Gigabyte 2070 from another PC and once installed everything played fine, had 13 hours play time yesterday with no issue what so ever.
The PC which the 2070 was removed from has had the same issues with the green screen while gaming but also when just browsing the internet. Drivers were installed one at a time up to the latest dated version and all had the same problems in the end.
The card is less than 2 weeks old so do you think it would be an option to return and replace?
specially all that power in the Xbox series
