Having a strange day so far due to the kitchen light. Kitchen light is a long fluorescent tube and it appears it's making items in the kitchen live. First noticed it this morning when I went to pick up the kitchen cloth, which is damp. Got what I thought was a static electric shock but every time I picked up the cloth I got a shock. I also go shocks off the ceramic tiles around the window but not off the kitchen sink, which I presume is grounded on the water pipes.
Didn't realise it was the kitchen light but my brother thought it was and turned the light off and the shocks stop. With the light on, the tiles around the window are round 80 to 90 volts but not much current (so far anyway) so it the shocks fell like a strong static electric shock.
The weirdest shock I've got is from the screw head at the end of the kitchen worktop. The screw is, I'm presuming, to hold the end trim onto the kitchen worktop so wouldn't be long and one can presume effectively insulated. However, with the light on then there's about 80 volts going through it which I found out the hard way when my face brushed it as I was measuring voltages off objects.
Does this problem ring a bell? Is it a problem with the tube or the light fitting? I replaced the tube a couple of weeks ago as the old one wouldn't stop on. The tube I replaced hadn't been used before but had been sat around for at least a year.
