quick math question please
Permabanned
11 Aug 2016
Cheshire
building a little decking area and using pallets to put a hot tub in a and a gezeebo.
pallets are 1200 x 800
decking 2.4m x 120mm
hottub is 180cm x 180cm square one.
TIA
My question is...what is the question?
But the decking is 1.2m wide, the hot tub is 1.8m
According to the OP, the decking is 2.4m long and 120mm (0.12m) wide. A plank. Going to be quite the balancing act in that hot tub :)
Not sure why they mixed m, cm and mm with such gay abandon though. Or why they didn't ask a question.
Put everything in the same units, ffs. Use mm or cm for everything. Are you saying it's a 2400mm square decking that is 120mm high?
