Sort of misses the point, no? Your rationale is just as applicable to visitors to those business sites... "Why shouldn't they do everything they can to support their browsing experience?"If you don't like the terms of a site then go somewhere else. Why shouldn't they do everything they can to support their business model![]()
If a website has opted to have ads on its site for whatever reason and has chosen to employ a method to ensure you don't block said ads either comply or sod off somewhere else.If you don't like the terms of a site then go somewhere else. Why shouldn't they do everything they can to support their business model![]()
both those sites work fine for me*REVIVING THIS - for those using ublockO .....*
it's increasingly annoying, where sites do not work correctly due to UblockO black-listing site rules, and, then,
dfificult to determine which rules as are causing the problem, and, maybe, relaxing those. - what's your approach ?
A couple of sites I tried/failed to access today
https://www.simplybusiness.co.uk/kn...mortgage-costs-fall-for-buy-to-let-landlords/ this has blurred images because of something on black-list
https://www.reddit.com/r/OLED/comments/av6c70/how_does_oled_deal_with_sd_low_bitrate_content/ functionality to see comments no longer works
thanks , very interesting, I see an obscured image on the first site (which I see on a few other sites too)both those sites work fine for me
Do you have a lot of lists selected in uBlock? I've found that sites can if you choose too many. Disable the lists one-by-one until you find the culprit.thanks , very interesting, I see an obscured image on the first site (which I see on a few other sites too)
and, for maybe a week, a view comments button that does nothing, on reddit
The view comments tab/button also works fine for methanks , very interesting, I see an obscured image on the first site (which I see on a few other sites too)
those 2 boxes to the left of the blue power button iconIn the case of the first example, it is actually not the white/black list that is causing the image blocking;
yes - you can disable ublockO for the web-site but that is rather self-defeating, you could, then, have exposed your system.
ublock log would suggest, the site maybe corrupting the images because I did not accept cookies - I had no prompt.
It accessed cookielaw.org, prior to rendering the page( with the failed images )
I do have don't allow popups and dont't allow 3rd party cookies, chrome options, set.
strategy to debug this kind of thing is a pain.
