Thanks but will it make a difference with that GPU at 1440p/60Hz?
Hi,
I have a system with an RTX2070 Super and an i5-8400. Is it worth upgrading the CPU with a used i5-9600k or i7-8700k for strategy gaming at 1440p (mainly Total War)?
Thx
Keep the RAM and sell the 8400 and Mobo, use the £130ish you'd get from the CPU/mobo and get the Ryzen 1600AF and a B450 Tomahawk board. You're outlay would be about £50-£60 and you'd have 6 cores 12 threads. Does more threads help with the strategy games? 1440p the GPU would be doing a fair bit of the grunt work.
1600 is a downgrade from the 8400 in nearly all games.
So that would be a really bad idea.
IMO the only worth while upgrades would be 8700k 9700k or sell up and get the latest gen AMD 3600x or higher.
Even at 1440p Warhammer II is still a CPU intensive game and also not optimised for multi-core. You are much better off going for a 9600k than a 8700K as it is newer silicon and even though the boost is 100Mhz less (4.6Ghz vs 4.7Ghz) it is much, much easier to reach 5Ghz clockspeed. It also doesn't have HT which is off little use to you and makes overclocking much easier. This will give you even more improvement over the ~4Ghz you have now if you're running at stock.Hi,
Thx
What clock speed are you at now? Which motherboard do you have?Thanks, I am also checking i7-9700 different versions, k non k etc...
While the 9700k is nice it would be a waste for you with Warhammer II, you'd get pretty much the same performance from a 5Ghz 9600K vs a 5Ghz 9700k. You're best bet is the 9600k, though if you can get a reasonable priced 9700K make sure it is the R0 (newer stepping), the older one is the P0. The 9600K only comes in P0.Thanks, I am also checking i7-9700 different versions, k non k etc...
Thanks, I figured as much. Hope you're overclocking that 9700K.I think the 8400's all run at 4ghz single core or 3.8ghz all core.
You can only over clock by 0.1
Best idea, solid upgrade path tooKeep the RAM and sell the 8400 and Mobo, use the £130ish you'd get from the CPU/mobo and get the Ryzen 1600AF and a B450 Tomahawk board. You're outlay would be about £50-£60 and you'd have 6 cores 12 threads. Does more threads help with the strategy games? 1440p the GPU would be doing a fair bit of the grunt work.
No, for games like Warhammer II it is a terrible idea. I have the game on both my systems so I know, I am not guessing/extrapolating like some.Best idea, solid upgrade path too
Thanks, I figured as much. Hope you're overclocking that 9700K.![]()
