This post is perhaps for my selfish benefit as a future point of reference but hopefully others find it on the forums and via Google.
So I've never had success in playing 4K HDR files on my LG 65C8 through the smart apps such as Plex, or the wildly better variant Xplay. They buffered from the get go. I put this down to the fact that the so called premium TV only had 100MB ethernet. I had previously read suggestions on trying 5ghz wireless instead, this was the same.
Cue me going down the rabbit hole and exploring Nvidia Shield, Vero 4K+ etc. However as I've got older I've grew weary of tweaking this, that and everything else. I therefore settled on being able to only play 1080p files via Xplay via 100MB ethernet via a Synology 218+.
After another recent attempt given current circumstances, I tried wireless again. Nope, didnt work. I then read people have had success in using a USB to gigabit adaptor, great for TVs which have USB3 but no, again LG decided to cheap out an installed USB2 on my model. Again, for the benefit of others this specific one is touted as the best by Cable Matters https://www.amazon.co.uk/Cable-Matters-SuperSpeed-Gigabit-Ethernet/dp/B00BBD7NFU/ref=sr_1_2_sspa?crid=1TM31M4KZB8JL&dchild=1&keywords=usb+gigabit+ethernet+adapter&qid=1586427318&sprefix=usb+gig,aps,157&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyWkdKUFRBM1AyN0dPJmVuY3J5cHRlZElkPUEwOTEzMDk2NFE5VFNMNElNSDQ0JmVuY3J5cHRlZEFkSWQ9QTA2MTE2MDUxSjFYOUxDTkpONjE0JndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I then started to question why, as in theory 5ghz should have enough bandwidth so is it a processor limitation on the TV. Various google pages across various forums, I stumble upon a year old Reddit post. https://www.reddit.com/r/OLED/comments/9tsank/lg_c8_55_slow_wifi/
And here is the golden nugget I stumbled upon on this glorious day.
As of today, I've successfully streamed an 80,000KB bitrate movie in glorious 4K HDR. Turns out these LGs dont like certain wifi channels.
Not - a - single - blip.
For my B7 I had to change my 5Ghz UniFi WiFi from auto to a static channel between 36 and 48 (non DFS? Also remove 2.3Ghz as it would sometimes connect to that instead of 5Ghz) turn off quick start and then I was getting over 150Mbps. The Ethernet port is 100Mbps so it wasn’t good enough compared to WiFi to stream large files.
