- 22 Nov 2017
Morning all
Last week our central heating stopped working. The boiler is still firing and heating the water cylinder but the radiators are not coming on. So I did some research and I found I was able to manually activate the radiators by manually moving the switch on the motorised valve in the airing cupboard.
No on the basis that I think the likely issue is either the room thermostat or the valve itself I purchased a replacement room thermostat. Since we move into the house two years ago the thermostat has on occasion made some buzzing noises so it is my likely culprit.
The existing thermostat is a Drayton RMT230 and is wired as per the image below:
As I understand it the blue connected to screw 4 is neutral the brown to screw 1 is the permenant live and the final wire (despite being yellow and green the colour for earth) connected to screw 2 is the switched live.
The replacement part is a Salus RT200 and has wiring as per the image below:
If I have understood the wiring in the original thermostat correctly the blue neutral cable goes to the top far left scre marked N, the brown to the middle of the three marked L and the final green and yellow to the third marked SL.
I think my understanding is consistent with the manual:
https://www.plumbase.co.uk/link/1/h032967_23215_t.pdf
I would appreciate a sanity check before I do the change over.
Many thanks
Darren
Many thanks
Darren
