The Division 2 - March 2019
Those toy trucks that carry explosives **** me off.
I have found that they normally have problems in certain areas when you hug a wall or go back and forth around a corner (try different areas) and then of course, your shotgun becomes your best friend.
I believe the only way to really run and gun is to throw on the Crusader/Striker shield, but even that is short lived.
I spoke too soon here.
I just switched to Technician, threw on the Crusader Shield and the Artificer Hive (holstered) and it's tanky.
Think i'll stick with this for a bit, but this is what i like about the game, testing other builds.
Being tanky doesn't mean anything in this game at the moment, not whilst you can have all your armour and a great swathe of your health stripped in one shot from across the map by a 'red' enemy with a pistol/subgun.
Or those big drones nearly killing you from rocket splashdamage.
It's just the crusader shield with the artificer hive. It repairs the shields health to full after a few seconds and repeats the process consistently.
I also have the talent that repairs 100% armour when you have 0% armour.
Yeah, I'd love to swap that 'Unbreakable' onto my chest piece, but it I'm currently running the 'True Patriot' set and it would really mess with my talents. I just need a True Patriot holster to drop so I can drop swap out the chest armour. But as with every game, the Gods of RNG seem to ******* hate me for some reason and I get everything but the item I want dropping.
Had a good run on the game Tonight.
managed to get everything now done for both the rouges and only got the bounties for each to do which I have saved to when I have a bit more time as unsure how hard/easy they are (running world on hard difficulty).
I found the bounties can be frustrating in that the markers will move around at each stage leading you to the eventual target. I tend to matchmake for the bounties as this generally helps find the target quicker.
At the minute i find im llogging in each time a new chapter of the season opens, get that part done then give it a break for a while. I dont particularly enjoy rinsing and repeating the content for upgrades esp given the amount of balance changes which make previous top tier builds tomorrows trash teir :)
I know what you mean, I don’t grind for the best gear or stats and just use what I come across as each update could make your set worthless.
I did the matchmaking as well for the bounties but I did everything else before solo unless o got really stuck. Now I have done the two current rouges I’ll take a bit of a break
I'm thinking about buying the Warlords New York expansion.
I have about 50 hours in the base game (I didnt buy any DLCs), I'm at level 30 with so-so gear.
What do I need to do with my old armour & weapons that I'm hoarding, sell, disassemble or keep for the recal station to extract abilities or talents?
Cheers.
Keep your good level 30 gear. I read somewhere they're going to allow you to level up the level 30 gear to 40.
What is the clan? I will try and get online tonight. I have been playing most evenings since Warlords release. Finally got to level 30, but still tier 1.
