msi h61m-p31/w8 bios
15 Apr 2020
Hi people, imo got a cheap PC on ebay and upgraded the gpu, cpu, cooling and all that but my motherboard which is a
msi h61m-p31/w8 uses the AMI bios if it is classed as a bios.
As ami version is from 2012 I wanted to update it or change it to a newer better bios to have easier to use settings.
Is this possible??
Cheers
Version
2.7
Release Date
2013-01-10
Description
- Update onboard Realtek LAN driver.
- Enhanced PCI-E display card performance.
- Improved memory compatibility.
Is the last Bios for that motherboard
No you can only update the bios and you cant change the AMI
After reading your last message again you will have the MSI bios already.
