Can you advise
13 Oct 2017
I have a gtx1060 it's EVGA SC 6gig one
Still going for £250 new here is my problem
My monitor is a freeSync but that needs a AMD card now I have been offered £180 for my gtx1060 card that would give me the money for a RX 590 which does support freeSync is it worth.me do changing from a
GTX1060 TO RX590 ?
Thanks D
GTX1060 TO RX590 ?
Thanks D
You might want to check before you swap as Nvidia have started to support monitors that support Freesync. A 590 is a small upgrade on a GTX 1060 6Gb but the 8Gb of VRAM may give the card a longer lease of useful life.
As the others say, it should work. Make sure freesync is turned on in monitor settings
Nvidia settings - setup G-sync - enable G-sync/gsync compatible - enable settings for selected display model.
Then download the free G-sync pendulum demo and if it shows the g-sync option in that - 'tis workin'.
See the person who wants to buy my card is on my advice he is using my old 960 at the moment and his PSU only has 6 pin and the EVGA uses the 6 pin and he needs to upgrade is GPU anyhow
So what if I added an extra £50 so with say £230 what would I be able to get.
And thanks for your help
D
I'll second what Infiniteey said.
1660 Super would be a better upgrade than RX 590. You'd be approaching 1070 territory from your 1060, with the RX 590 you remain where you're at.
