Bit of background, trying to replace the tap in our kitchen and the feed pipes have the standard 22mm nuts to connect to the hot and cold feed pipes.
However for some reason (always the case in our house!) the feed pipes are connected with 32mm (I think) plastic screws and valves.
Is it possible to get a valve/adapter that will allow me to connect the new tap hoses to the existing 32mm setup?
they make me cry!!
