Cables and Snake Oil
24 Aug 2006
My dad says he's got a new power lead for his CD player and that it sounds richer when using it.
It's kind of upsetting me because I'm pretty sure this is impossible. He spends large sums of money on all this stuff.
There's no way he can hear the difference is there?
19 Jun 2009
It's probably true, power cables can make a difference especially at the very high end.
Man of Honour
13 Oct 2006
I'd say unlikely rather than impossible - unless you are starting with a very poor quality cable to begin with it isn't likely any difference would be noticeable.
19 Jun 2009
He's actually got a PS Audio CD player, which given the cost, you'd think it would come with a good power cable?
PS Audio actually explained this in a separate video.
They don't include a better cable as it would drive the price up of the CD player.
6 May 2009
Get him to do a simple blind test of the expensive one and a standard one x3.
If he guessed correct 3 times then he probably right.
I don’t believe it makes much difference personally, unless the old cable is all mangled up with the shielding missing.
R3X
R3X
9 Aug 2013
Swap the cable when your pops is making a cuppa with a £1 pound shop one and announce the change over 1 week afterwards over WhatsApp ;)
2 Jul 2019
People talk about "burn in" on solid components in the audio world too, it's quite odd.
I'm not an electrician, but surely you're limited to the "quality" of incoming mains to your house anyway. Just like broadband and even water.
OP
24 Aug 2006
You know, it's not a bad idea. I think it will upset him though, which I don't want to do.
OP
24 Aug 2006
He goes on about this too. He was burning in the new amplifier recently.
Man of Honour
13 Oct 2006
Some electronics components do seem to have some kind of burn in period though it isn't automatically a thing and whether it is an improvement or not another matter - I have a box of OPA1612 op amps and I can tell right away which ones I've used for any length of time before versus new ones without even checking.
22 Nov 2018
Surely he has standard cheap electrical wiring to all his household power sockets though. The quality of the power can only be as good as whatever cable the electrician used in his property.
How far can you go for high end audio then? A dedicated power socket with a high end power cable to the fusebox? A high end fuse in the fuse box? Then there's the cable connecting the house to the grid. Non of it is high end. I dont understand.
Caporegime
8 Jan 2004
Rutland
Surely he has standard cheap electrical wiring to all his household power sockets though. The quality of the power can only be as good as whatever cable the electician used in his property.
This! It's utter twaddle to think that last metre of power cable makes the blindest bit of difference.
Just seen the price of some of that Russ Andrews gear, ouch!
18 Oct 2009
Definitely this.
Audiofoolery deserves to be exposed.
You can expose it, but that won't make it go away. It's like a religion to some people.
If the man in the sky with the white beard could be proven not to exist, that would not stop people continuing their religion, just as you'd still get audiophiles continuing to believe in the improvement ever more expensive cables bring to their audio system, if someone could prove it's just placebo.
Heck, look at the flat earth brigade. Plenty of evidence of a spherical earth, but they aren't having any of it :p
Prove all you like, but none of that matters to those who believe. ;)
2 Jul 2019
Dunno what that is you've got, but i imagine tube amps likely change a bit through heat and wear. Never had a tube amp sadly, but do like the ones i've heard.
30 Nov 2011
I think like most that expensive cables are a joke. As long as you aren't using the cheapest possible stuff.
With regards to burn in on new amps/speakers etc. That is more you getting used to the change in the sound, not the unit changing in my opinion.
