hey thanks for the site
I'm pairing a msi b450m pro m2 max with a ryzen 3 3200g in a coolermaster N200 with no dedicated graphics for now.
I'm not an overclocker or a builder so I have questions.
the 4pin cpu connector and lack of vrm heat sinks make this board less than ideal for overclocking but am i correct in thinking a slight oc is still safe with this set up?
I'm using the stock wraith cooler and 2 case fans for now.
I'm hoping the ryzen 3 3200 g is a good candidate because of its 65w tdp.
cheers
*turns out i was looking at an older version of the board and the cpu pin is actually 8 and it might now have voltage offset so that will help with any precision boost overdrive overclocking
**Hardwarel Numb3rs monitors vrm temperatures on a 3 phase msi b450m a pro for science:
cheers
