Hello there.
My Fridge Freezer has literally just packed up - dreadful timing.
It was a LG GRF459BSCA - if you type that model into Google, virtually nothing comes up, so it is pretty old and definitely not worth trying to fix.
The serial number begins with "801", which suggests the very beginning of 2008.
I have done a bit of research and have overwhelmed myself a bit.My main requirements are that I do not want a water dispenser (our old one had it and we literally never used it).
The fridge should be tall (given that we have a high roof in our kitchen), but no more than about 60 cms wide.
How much is it reasonable to spend on a fridge freezer, these days? (e.g. is there a minimum spend to get something worthwhile).
Are there any brands to look for/avoid?
What sort of rating should I be looking for? A+ and A++ seem the norm at the moment - is it worth paying more for the latter?
Any pointers would be very much appreciated.
