This is a bit premature, but I'm hoping I can get some early tips to get me thinking in the right direction as I start to plan.
My (pre-built) PC currently has a Coolermaster Masterliquid Lite 240 AIO cooler in it. It's always been a bit problematic.
If it gets hot enough for the fans to go to high speed, one of the fans catches on the edges of the rad they're attached to and (as you can imagine) makes a racket. I got the fan replaced under warranty but the new one did the same. Eventually I stopped it by adding washers between the rad and fan to give a tiny bit extra space. Or at least I thought I did. Turns out it still happens very, very occasionally. Presumably only when they hit 100% speed and that's very rarely needed.
Anyway, even aside from that problem, they sometimes seem to cause some kind of resonance in the case which buzzes. Not very loud, but the type of buzz that's really quite grating.
I've been lazily putting up with this, because it's sporadic, for 3 years. But I'd quite like to do something about it, and lockdown seems a good opportunity. This is because the PC is usually down low and under a desk and hard to get at to investigate as the sounds happen. With lockdown meaning no visitors, I have wifely permission to have it on a table at the side of my desk instead, which will be messy and in the way - but will give me much easier access to look it over in operation and plan!
Anyway, my initial plan is to just get rid of the AIO set-up and fit a good air cooler and twin 120mm case fans at the top.
Can anyone give me good advice on what case fans and what CPU cooler to go for? And any more general tips, as I'd consider myself a complete beginner despite having tinkered a bit with upgrades and the like over the years.
If it makes any difference, the CPU is an i7-8700k on an Asus Z370-P motherboard.
Case is a cheap thing I've never heard of - a "Game Max Falcon". There's plenty of space for a big cooler (but removing the rad from the case fans will be beneficial as there's not a lot of space in that area of the case next to the DVD drive.)
Depending on what thoughts I get back, I can look closer at how everything currently fits together if it will help. That's my intention for my own planning anyway. I'll pull the PC out and put it on the table this lunch time.
Massive thanks in advance for any advice.
