- 5 Dec 2013
Just bought a used 1080 for a decent price. I suspect it's probably been used for mining, but the manufacturer stickers are dated April 2018 so it can't have been mined with for several years. Everything works great so far, but idle temps are a slight issue plus I want thermals as perfect as possible to maximise lifespan.
Load performance is absolutely fine but idle it sits between 45-55 and often needs fans even with less than 10% load.
This is the PCB of the card
What's going on with the black discolouration in the centre? Is this serious heat damage or fairly normal signs of (maybe quite heavy) use?
This is the thermal strip on the cooler
I'm completely new to these things but this looks in pretty bad shape to me. Plus the ones on the PCB look awful and cracked and definitely need replacing. I measured the strip on the cooler as 1mm so I've already got Grizzly 1mm thermal pads on the way. Do I need to replace every single pad on this card with the new 1mm's?
I cleaned a bit and replaced thermal paste but left everything else as is.
From the repasting, load temps and performance has improved significantly and now matches reviewers benchmarks. I feel like the fans are working slightly harder than they should need to under load. Idle temps are still an issue and I feel like both this and load performance could improve drastically with new thermal pads?
Any insight/advice much appreciated
