Hi,
I just built an AMD PC, however, the RAM I got(Corsair Vengeance RGB PRO 16GB (2x8GB) DDR4 3600 (PC4-28800) C18) turned out to be a faulty one. Did the tests mentioned on this forum(Removed one stick and tested with a single stick), both sticks fail(Ran memtest86, found multiple errors). My motherboard is Asus TUF x570 Gaming Plus paired with a Ryzen 7 3700x.
I was looking at:
Team Group Edition 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit as a replacement. Its not listed on the Memory QVL, however on the below link, it says its Ryzen 3000 8 pack approved and compatible.
https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-08q-tg.html
Could someone please help me with the decision as the other RAM modules that I have looked at which are present in the QVL are either very expensive or out of stock.
Thanks
[Edit] updated with the test name and methodology
I was looking at:
Thanks
		 Although I can't yet afford 32GB, I will go with the 16GB for now.
