- 3 Oct 2014
Just drive around in second gear for a while, you don't have to go on a motorway.
Can confirm this is nonsenseShort trips to the shop's and just running around town kills the dpf, they need a motorway run to start the the regen phase.
Short trips does not get the oil, coolent and dpf up to temp. The dpf gets clogged and in some cases gases will find another way out, It’ll get to the point where forced regen will fail. Too many failed regens will dump diesel in the oil like the Toyota urbanCan confirm this is nonsense
It won’t regen if the temps are not right as dpf needs to get really hot to burn the soot into ash diesel take longer than petrol to get up to temp. But newer cars maybe different.Sure but it isn't as bad as some say - as I mentioned on mine for instance regular at least 10 minute trips with the speed not dropping below 10 MPH is sufficient to maintain the DPF. You don't need to be doing motorway trips frequently to prevent DPF issues with it.
LOL at how you guys need a motorwayShort trips to the shop's and just running around town kills the dpf, they need a motorway run to start the the regen phase.
I’ve had loads of customers with diesels because “their cheaper to run” and only used as a shopping trolley. Forced regen fails and the only option is a new dpf £1000+ fitting or remove and send off to clean, cleaning is not 100% guaranteed to work. Had taxis with no problems with dpf.
In guernsey there thousands of diesel cars and the whole island is only around 7 miles long and around 3 or 4 miles wide![]()
if you are geek inclined, and have a 'code' reader + appp, can you typically do a health analysis of your dpf, and see if it nearing/needing a refresh, and even provoke it.
Guessing you have a newer diesel? Probably using extra fuel to get up to temp which could be why some dump diesel in the oil.Manual on mine says it only has difficulty burning particulate matter if you drive below 10 MPH for a sustained period of time and/or regularly stop and start the engine within 10 minutes.
It recommends a ~40-45 minute run at 50 MPH "periodically" (or if the warning light comes on) if you regularly drive under those conditions but otherwise the DPF condition should be maintained without needing to do that.
Obviously different vehicles will vary.
Renault make F1 engines but what the hell where they thinking combining the oil filler cap and dipstick?Newish but not that new now https://en.wikipedia.org/wiki/V9X_engine it is a bit different to other diesels but I've seen similar in the manual for other diesel engines as well.
No Need as Guernsey a beautiful place to drive around with it having only around 70,000 vehiclesMy sympathies.
(Of cause this was filmed before the lockdown)
