- 13 Jul 2006
- Hell!! \m/
Hey guys, I've not been in the gaming scene or PC hardware scene for awhile so I have some catching up to do. I wish to upgrade my PC to run games in VR on high GFX at 90FPS. I have a normal Oculas Rift which I've only just started using. My current computer struggles a fair bit but I'd put most of that down to the fact I am using a 250GB SATA hard drive at the moment. I don't do a lot of other power intense processes. I would like to ideally do the new pc build/upgrade (whatever you want to call it) in two parts the mobo, cpu, ram then another date the GPU and a new monitor.
So current spec is this.
Windows 10 and it's running off a hard drive right now, so I would say I would see the most benefit from upgrading this to SSD.
CASE: Coolermaster Cosmos 2 (I plan to keep this)
PSU: OCZ 1250W PSU (I might as well keep this too)
MOBO Asus Crosshair IV Formula
CPU: AMD 8350 4GHz
RAM: 16 GB (DDR3?)
GFX: Nvidia 970 GTX
This is what I've laid out to upgrade it with. I'm undecided on what to get the PCIE3 SSD or the 2.5" SATA one? I'd assume the PCIE one would have more benefits than just small size and takes up less space.
https://i.~ibb.co~/S3YWjkr/SPEC1.png #
I'll need to order 2x USB 3.0 extenders, a third Oculas sensor, a VR pully also. Then in a few months I'll probably invest in a new GFX card and new monitor.
CPU: AMD 8350 4GHz
RAM: 16 GB (DDR3?)
GFX: Nvidia 970 GTX
