My £1200 System
I've tweaked the spec a bit:
Bit cheaper Ram & I doubt you'd notice the difference
3600X is not worth it over the 3600
Much faster SSD (the one you picked, speed wise you may as well got a SATA SSD)
The cooler I picked will do more or less the same job but cheaper
PSU is in stock & Fully modular - Seasonic is partially modular.
Corsair is OK, if you want that case go for the 275 Airflow as its cheaper & will be better for airflow, but this is the best case for airflow for its price right now.
My basket at Overclockers UK:
Total: £1,238.03 (includes shipping: £13.20)​
