You generally need quite specific circumstances for a reactor to cause irradiation of note - the runaway cook off at Chernobyl doesn't easily happen by accident.
There was a stunning end of the world nuclear plane / rocket that the US developed if I remember correctly, it would fly in circles dumping radiation on the ussr.. They decided to scrap it when they realised the USSr were making or would have to make their own.... I'm sure it was up and running (maybe a more efficient version not dumping radiation everywhere but it was easy to make it throw bits if the reactor out the exhaust)
The USA had one of those planned too. IIRC it was called Project Pluto. A fitting name, as Pluto was the god of the underworld, the god of death. They tested it. It worked. They binned it for being so nasty that just having it might provoke the USSR into war.
Nuclear reactors don't usually hit the ground at hundreds of miles per hour, break up tens of thousands of feet above ground or crash while taking off or landing at a busy airport.
That's not actually true. The Soviets sent reactors - not RTG units - into space. And reactors don't just explode. An airplane in a crash would not irradiate a large area if the reactor broke.
Containment is not an issue. They drove a train into one.
Ah yes was it one of those 600mph trains,
It's the energy of impact that's important.
Indeed, did you forget the bit where kinetic energy is proportional to the square of velocity?
Of course not. Why are you assuming I did?
By the time this thing is made they will have better batteries I think.
The problem is radioactive debris being scattered everywhere after a crash.
