Northern Ireland Water-Cooling Builders
10 Aug 2009
Banbridge, N.Ire
Hey folks, this doesn't seem to have been asked in a few years, so are there any water-cooling experts in N.Ire.
I want to go water-cooled but don't fancy doing it myself as it's a very small case, so could be a tricky build.
TIA
Use soft hose mate its very easy to do and I'm sure the lads on here will help guide you
I'm giving it ago for the first time, using soft tubing, just got to order CPU block and Pump/Res combo...
I'm nervous about it but I'm sure I will be ok, I'm a quick learner :)
If I was over your way I'd help :)
Building a loop for the first time seems like a daunting task, but there are plenty of online videos to show what you need to do, and guys here with loads of experience.
The most important part, is the leak check to make sure everything is ok before powering up the entire system.
Well the first thing I would like to know if I do decide to go ahead, I want to do a 240mm rad and a 120mm as that's what my case could fit. Looking to cool both CPU and GPU. What would be the flow order from pump/reservoir to CPU / GPU and rads?
Thanks
As long as the reservoir fills the pump first then loop order makes no difference as it will equalise over time- whatever makes the loop nearer or pleasing to your eye
I'm kind of in the same boat, going to upgrade to a better air CPU cooler and add a few fans instead now. I would love to go all out on a water-cooling loop, but I think my case is too small really but don't want to change it. Cheers for quick shout back btw. Happy new year.
Yeah I've gone with a new Air Cooler instead, it does a great job just doesn't look as good/funky as having a loop...
Happy New year mate
