I want to get a sinch more performance and much lower accoustics from the my MSI GTX1080 GamingX.
I've seen on youtube, someone use the g12 on the GamingX with the baseplate/front plate in tact, which
should help take care of the heat from VRMs.
I was after some opinions on how to setup my case the Corsair 680x. I currently have a Antec Kuhler 920,
49mm radiator AIO. Its at the rear of the case.
I want to add a 240mm or 280mm AIO with the Kraken G12. Question is where can I put it? And it seems
the 280mm wont work on the roof of the case as the Kuhler 920 will be in the way.
So attached are two pictures, where would you suggest I mount the 240 Kraken X53 dual radiator AIO.
And should I use the Kuhler for teh GPU and the X53 for the CPU?
fyi-rear radiator config is push pull
Heres the shopping list:
- Kraken G12 - £25
- Kraken x53 - £120
- MX-4 thermal paste - £5
- VGA to 3pin Fan connector - £10
- Riser cable - £50
