 - 24 Apr 2020
Morning all,
New to the forums, new to gaming. Basically new to everything, however....
I have a M5A97 R2.0 Mobo with the FX 4100 Cpu.
I'm looking to upgrade the chip but need some guidance on what to go for, it's an old machine so i'm probably best sticking to FX series over Ryzen. Is the 8520 a decent upgrade? And if so, how much should i expect to pay? (Did look for a marketplace here but couldn't locate one).
I'll more than likely buy second hand as it isn't a PC I expect to spend thousands on.
OR.... Would it be worth just going all out and buying a board and CPU second hand? Again, if so, recommendations and guestimate for said recommendations.
Thanks one and all.
Thanks one and all.
