- 27 Dec 2005
- Bristol
Presentation is everything.
What an absolute waste of packaging...
Which model are those, they look just like oklays
New tools. Shiny.
New tools. Shiny.
I actually could do with that....I have no experience regarding tools, is this good bang for buck? It's only £27 on Amazon.
Luxury to have all the bits already in a socket you flash git.
Nothing beats trying to find the socket for the bits for hours
Bacho do one that’s similar but much more compact, think it goes up to 13mm sockets
That’s the one. It’s really compact so it lives in the house most of the time.You mean this one?
https://www.amazon.co.uk/Bahco-SL25-Socket-Piece-Drive/dp/B000Y8XCA8/ref=sr_1_1?crid=PSPSBRLX4YBO&dchild=1&keywords=bacho+socket+sets&qid=1589051148&s=diy&sprefix=Bacho+socket,diy,143&sr=1-1&th=1
What really bugs me is that if you get that and you want more tools...the larger sets overlaps.
https://www.amazon.co.uk/Bahco-S330-Socket-Piece-Square/dp/B0001JZRYY/ref=sr_1_5?crid=PSPSBRLX4YBO&dchild=1&keywords=bacho+socket+sets&qid=1589051148&s=diy&sprefix=Bacho+socket,diy,143&sr=1-5&th=1
Ideally I want to start with the smaller one and possibly expand as I need to without overlapping.
yeh these can get ridiculously cheap now and again ,i have a small set ,i am trained as a ford technician ,we used to have a snap on van come round ,that costs a fortune but is awesome (or was back in the day)Halfords professional range tools are excellent. They're regularly on offer too.
Edit. I've got the Halfords 200 set. More than I'll likely ever need.
still pricey https://shop.snapon.com/product/Metric-Sets-A/Complete-Metric-Set-A/9100GMBO
That looks great, i never knew you could get an adapter like that for the console.Having problem playing PS4 with a controller I found these and thought I buy it so I can get around to play The Last of Us among others. It's an controller so you can use mouse and keyboard. So instead of using a normal sized keyboard I bought a very small one, which covers all the functions that the Tin200 'converts' from controller to keyboard. And since I needed new keyboard and mouse to use the converter anyway, they were also of the same brand to make sure maximum compatibility. And a mega mouse mat thrown in there as well for good measure.
Only problem is... I started playing Mass Effect before I got the goods and now 'addictive' to that game so be a while before using these.![]()
