Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Hello all,
I want to make a garden outdoor table like this one to put my Bonsai Trees on, minus the small side table it has here. I know nothing much about woodworking, I only have a Borsch Drill and drill bits, no saw, no spirit level, consider me a blank slate.
Just thinking out loud.
1 - I want it to be around 2m long? It’s going to go into the corner of the garden so I could make 2 of these and put them as an L shape so I may need a middle section to support the centre to prevent bowing. I want the least cutting as possible as I will be doing it all with hand tools. https://www.diy.com/search?term=c16+treated+timber. B&Q sell lengths of timber at 2.4m lengths so if I use that, I will need a support in the middle I expect.
2 - I found out I best get C16 treated timber, and like the photo, use Decking as the top as it is designed for weather.
3 - The biggest thing going round my head is how to connect it all together. In the photo the horizontal plank going lengthways is attached to the corner posts by screws from the side. That means all the weight of the entire worktop is going through those screws. Is that strong enough? I thought about placing the horizontal plank on top of the post and drill through from the top, or even make like an Ikea joint and have it sit on top. Someone however said that’s a bad idea as I will be screwing down the post at the end which is it’s weakest, even though the top plank will act as a cap?
In the photo he has a centre horizontal plank going across, I don’t however see how it is supported at the ends...
Also, what stains would I need to paint on top of it to make it last the longest?
Anyone have any input on how I should go about this and what sort of tools, material or method would be the easiest way for a dummy like me?
Thanks
Thanks
