Hi,
Not long got hold of my 3900x - coming from Intel historically I am trying to get my head round how it works! Always used to OC my chips but having a play here it doesnt seem to have much point in even messing with OC as results arent much to talk about for the effort.
What I am really keen to do however is drop the voltage as by default, my Mobo wants to drop 1.47v through the CPU and idle temps are around 50c!
Doing some testing using Ryzen Master I can get a stable 4.25 all core at 1.3v, with PBO disabled in the BIOS, which dropped idle temps to about 38c. Though I am sure I am better off leaving PBO on in BIOS as it did boost higher than 4.2.
If I was to just put a manual vcore of 1.3 into the BIOS and leave everything else auto would this work the way I am hoping?
Away from my PC at the moment and just thinking about it so cant test, but ideally want run this by people with more experience with Ryzen 3s
From searching the net it seems that OC is generally a bit pointless and better to focus on the RAM?
