- 29 Dec 2014
- The "North"
Hi all,
I have a build coming up which I'm trying to figure out the fan configuration for and I was wondering if anyone has any advice for the case and cooler fan configuration.
I'll be running a 3700X and 1080TI (Open cooler so dumping heat in the case) and any fans used will be Silent Wings 3's
So far I was thinking of 3 fans on the front for intake, 1 on the rear as an exhaust and 2 on the top as exhaust.
For the DRP4 I was going to use the stock config of two fans to pull from the front and exhaust through the rear.
However, I just noticed the DRP4 can take a third fan and because of this if it was worth adding one to allow the fans to spin at a lower RPM to reduce noise
Does anyone have any suggestions for the case airflow or if a third heatsink fan is worth it?
Any help is appreciated
