Hi all, using an Asus router at the moment, it works fine but working from home with myself, the wife and daughter using a myriad of voice apps etc im struggling to get a decent service.
QOS is configured, but I want a bit more.
Am taking the plunge and ordering a second internet connection, What firewalls would you suggest to help me with WAN Balancing? I want to be able to grind down fairly deep into the rules so that some traffic (or nodes) use a primary and secondary gateway (this are likely to differ based on rule), while others can only go out only through one gateway.
not overly interested in additional features like IPS/DPS, Logging, Reports etc. I use a HTML5 gateway for RAS, so SSLVPN isnt a necessity - I have no issues in investing in a USG if my requirements above are met, although i don't think I will use many of the other features.
any recommendations? what have you guys installed?
