i7 or i9 upgrade help
19 Apr 2003
Milton Keynes
Currently have an old i5-2500 and Asus mobo that i would like to upgrade for gaming and video editing while im stuck at home.
Components i want to keep from my system are as follows.
Aorus GTX 1080ti
Samsung 860EVO Sata
Corsair HX750i power supply
Obsidian 750D case
Have around a grand to play with give or take and just dont have a clue about what the best route would be so after some help.
Many Thanks and best wishes for any help or advise you can offer.
1 Dec 2015
Aorus GTX 1080ti
Samsung 860EVO Sata
Obsidian 750D case
If using Adobe then intel still wins, regardless if you Chuck AMD cores at it. Current intel 9th gen are superceded with incoming 10th gen that unlocked hyper threading .
Also AMD side , b550 is launching with b450 and x570 not supporting Ryzen 4*** CPUs coming end of the year
My basket at Overclockers UK:
Total: £750.47 (includes shipping: £10.50)
Or wait for b550 Aorus Master/Pro £150-220
Intel
E
Total: £885.47 (includes shipping: £10.50)
Least your doubling your core count and thread count up by x4 !
32GB maybe overkill but added it due to video editing. Can always drop to 16GB
OP
19 Apr 2003
Milton Keynes
Intel
E
Many thanks indeed and do use most Adobe products.
What would be a decent Cooler for the intel build?
1 Dec 2015
Aorus AIO is rated best of the CLC units beating NZXT etc , has OLED screen and ARGB.
Eisbaer is good price and proper Copper AIO/water unit but not flashy or smart tech.
Dark rock Pro 4 , beast of an air cooler
Total: £409.79 (includes shipping: £9.90)
10th gen 8 core 16 thread in theory runs a little cooler due to design, but if manually overclocked to 5.2ghz all cores then it shoots up with temps !
Unfortunately , they haven't dropped 9900k 8 core 16 thread prices, they are exactly the same currently as the new intel 10 core 20 thread i9 being £500 both.​
14 Apr 2014
East Sussex
1 Dec 2015
Similar price to AMD build above - but 12 core and B450 motherboard, 32GB of 3200mhz RAM
Total: £728.47 (includes shipping: £10.50)
£115 for b450.. nuts and I'm an Aorus fan. Just grab b550 in June or x570 Gigabyte UD or Gaming X £150-70
Also, 12 core Ryzen doesn't beat 8 core 8 thread 9700k in Prem Pro.. Yet anyways . Adobe focusing on GPU support more now though
15 Oct 2019
Uk
1 Dec 2015
^^^ 38mm aluminium rad for the Arctic Vs 25mm copper for eisbaer.
Cut that open at end of 3 years and see the corrosion .
Pump is double the sound and less powerful too .
Fans are Stella though ! 6mm inner diameter Vs 8mm of the eisbaer for flow too.
Also 12 have design of the Aorus is better. Not using doublers and straight phases. 50amps Vs 55amps of Toma though
Although, 11th gen 8 core is meant to out perform the 10core 10th gen, so didn't spec it . Gaming wouldn't see to much difference as well. Save the cash :)
Same 10600k had a price rise though !
OP
19 Apr 2003
Milton Keynes
15 Oct 2019
Uk
Would this be any good as i would like something to build now and im not impressed with the latest intel release to be honest.
Sorry for being a pain.
Total: £951.42 (includes shipping: £0.00)
Looks pretty good although at £220 the cooler is quite pricey.
OP
19 Apr 2003
Milton Keynes
Many thanks for all the help.
All the above arrived from OC and spent the day today putting it all together.
Very happy indeed with the build and speed plus look fantastic now.
Many thanks once again for all the help and advice.
OP
19 Apr 2003
Milton Keynes
Pics orbit never happened :)
fairly happy with how tidy it is and looks awesome when all lit up
URL][\img]
