Good place to buy POSTERS (movie, game TV-Show) in standard 'A' sizes?
Suspended
29 Jul 2011
In acme's chair.
- Will just preface this with the fact that I have mountable poster frames in specific sizes, which is why I am being a fussy arse.
Hi guys, I have been trawling the internet for ages trying to find a House MD poster in either A0 vertical or A1 landscape, or perhaps even A2 vertical, and I have been having no luck... I've tried all the usual places, but I keep stumbling across websites that make/sell posters, and they don't come up in the search results when I am looking, but so far none of those even have what I want.
Most are daft sizes measured in inches or millimetres which aren't the same dimensions as the 'A' sizes...
Anyone know of a good source I may have missed, or even somewhere which can perhaps make custom posters that won't break the bank and I can send them an HD image? (Unsure how that would work in terms of copyright etc because I obviously wouldn't have the rights to the image)
If all else fails I'll just buy some other size and either trim it or buy something to make a border with.
Taa!
I had the same problem when I wanted to buy some film posters for my man cave. All the ones I could find were in stupid sizes so I couldn't get a standard cheap frame. I ended up having to buy custom sized frames to suit them.
Yes lots, but please see the bit where I said about weird sizes that aren't A1/2/0 :p
I clicked on one of the posters and the 'medium' setting said 59 x 84 cm which is A1, I work with 594 x 841 mm page sizes (with small border) which is A1 in the architectural world :)
This may help you dude, makes it easy to convert inches & mm to A-Paper size -
I miss those Athena shops that used to do loads of posters. Bought so much crap in there for my walls in my teenage years :D
Thanks mate. I had been Googling it every time, but I'll just leave that open. :p
Hope you're keeping well? The Audi back together and working?
Well I've ordered a GIANT A0 "This is House music" poster, which was mostly the right size... :p
