Hi pc i bought fron Overclockers not working?
I recreated your problem last night. Tried to install chipset drivers on a fresh install, hard crash. Same with Radeon package.
Updated Windows fully, then tried again... no issues, all nicely installed...
OP, did you fix your problem by installing windows 10? interested to hear if you got this resolved.
Hi no i even bought a genuine key for windows 10 to see if this helps and the same problem.
I rma'd my graphic card and memory and got thrm back today and it is the same errors.
I re installed win 10 pro.
Windows loaded.
For some reason it automatically installed some display driver and hey presto.
No signal again.
Booted into safe mode and rolled back display driver, restatted and eindows loaded again.
Downloaded and tried to insyall the chipset drivers.
Halfway through, no signal again, great!!!.
Driving me insain you could say.
Any ideas please?
Did you install all the amd drivers to latest versions after fully updating windows?
Plus when windows 10 auto installs the display drivers i get a no signal error message?
So i have fully updated win10 drom updates menu.
Restarted all fine.
Looked via device manager and it all looks updated.
Installed or tried to the amd latest drivers.
It was installing untill the 70% mark the screen off no signal again.
Rebooted to safe mode and rolled back display driver now it is back to microsoft display.
So i can get back on windows.
It is just after installing the amd package i get errors?
What am i sippost to do now ro get the best drivers for the graphic card?
What are your CPU and GPU temperatures? Stupid question but are you sure you have your cooler fitted correctly?
Do you have an old GPU from another system you can test with? Another PSU you can test with?
