- 18 May 2010
- London
same place as the membench section, just choose 'default' form the drop down menu and let it run.
What's you default score in dram calc? 210 and below is very good. Under 200. Excellent.
No, but I think if you bring tfaw down to 4*trdds +2/+4 and trfc to 340ish you'll be on it. The latter one depends on your ram... Is it b-die.![]()
224.49
Not great then?
@VincentHanna What RAM do you have specifically?
Tbh mate I don't know.@lnoton is that bad?
I always have to be honest.Treat me like an idiot
Haha. I was joking manHarsh
You still annoyed about my Deus Ex:Human Revolution comment?
I'll check these things later today, thank you.
Oh yeah I remember that now. Nothing to get to be annoyed about thereHehe, I did a quick search for previous interactions and that was the only thing of note that came up.
I said certain NPC's were immortal and that you couldn't kill David Sarif.
You uploaded pictures of you doing that very thing...I didn't realise you could kill him at the end of the game![]()
Is it b-die? You can find out by doing an export from thaiphoon burner.
I think your results all look good now to be honest. I doubt you can go much further.
What are your volts for vdimm?
Weirdly, using the fast result settings, with XMP import has increased my MEMbench latency from 213 to 222!
Think I'll go back to my old settings...
Not necessarily more accurate, but should give tighter timings etc as it knows its better stuff. You can select b-die in the drop down of the calculator.Right I've exported both of my Thaiphoon Burner reports to Complete HTML files and imported them to DRAM Calculator.
They are both the exact same and are indeed Samsung B Die.
So should the results for DRAM Calc now be more accurate?
I've no idea where the tRFC (alt) value goes in my Gigabyte/Aorus BIOS either, I only seem to have tRFC / tRFC2 / tRFC4
